Is there a quick way to undo every thing and restore to start of the session?
RKRK OS Professional Posts: 16 PRO
Can I quickly undo everything and restore to the beginning of the day or session or a given time?  I may have missed a feature which is already present.  Right now I am going through the "Show changes" list, then wait for the tool tip to show up to know the date and time.  I realize that creating a version before starting would help.  But in most cases, I do not have a version created and then there is the need to restore.
  • RKRK OS Professional Posts: 16 PRO
    @mahir, Thank you for your input, I was not sure if this option was available somewhere.  Sure, will put in an enhancement.
    @RK, Onshape automatically records the state of each tab (Part Studio, Assemblies, etc) at each persisted change made to all tabs for every workspace by every user. This history of modifications is listed in the flyout. At any time you can click Restore to restore the branch/workspace to a particular point in its change history, click Return to <branch-name> to return to the currently active branch at its current point in history, and click a history point to visualize the design at this point. In your history, select the "Show Changes" under Main then select the step before up-to your starting session and hit the "Restore" button up top.
    Please refer below video for more detail,
  • robert_scott_jr_robert_scott_jr_ Member Posts: 754 ✭✭✭
    I want to restore to a point before a session also. https://cad.onshape.com/documents/77bbcfc968fa5b0eff4f5aef/w/cce92091a7cd81ff540a6d10/m/f2336c9689728c6952ef85d7/e/52f636d7dec58e129de35345 The posted video shows how to accomplish that by the use of options provided by the gear icon. I attempted to do the same but the gear does not show on any of the history of changes listed. I guess I'm missing some thing. Help please. - Scotty
  • EvanReeseEvanReese Member, Mentor Posts: 2,856 PRO
    I'd love a feature like this. Even just adding a visible time column for every microversion would go a long way for me. It would be nice to automatically load the next set of microversions as you scroll instead of having to click the "show more changes" button. Those two changes would make it pretty simple to scroll to the beginning of the session, but still give you a chance to review that microversion to make sure it's what you want before restoring it.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    @robert_scott_jr_ - that's a very old video - you now right-click to see the menu
    Thanks for responding. I did see the notation at the bottom of the history window. I did right click as instructed but the only option was to create a new version. - Scotty
    Don't select the entry first - that will take you into viewing the microversion - go back to main, then right-click the entry you want to restore
    Ah, that's it. Thank You.
