dwg's importing slightly off target
derek_westwoodderek_westwood Member Posts: 34 ✭✭
I am importing different dwgs into different Onshape sketches and there is a slight discrepancy between the placements (1.982mm) can I move one of the sketches relative to the other to correct this?
https://cad.onshape.com/documents/40eee2f8c85ec0d819a0174c/w/eba0e571a3dcdc05bce3053d/e/6daadf3d63982dbe5c47bb8f
    dirk_van_der_vaartdirk_van_der_vaart Member Posts: 543 ✭✭✭
    Select the part of the sketch you want to move and use the Transform tool
