WEBGL problem in google chrome
sebastian_wolfenson
Member Posts: 7 EDU
Hi, I come with a problem that I can't solve. I have Chrome and I can't open the files because it says:
It looks like your browser doesn't have WebGL enabled. Click here for more information.
I made several tweaks in Google Chrome and I could not reach anything.
Any information on what things I would have to activate or how to fix it?
This started to do now.
Can you check the steps outlined in our help documentation: https://cad.onshape.com/help/Content/webgl.htm#WebGL also, there is a blurb about blacklisted graphics cards for WebGL listed here: https://www.khronos.org/webgl/wiki/BlacklistsAndWhitelists.
Since a few days I've the same problem here on two of three PC's with Chrome versie 79.0.3945.88 (Officiële build) (64-bits).
I checked your suggestion, however without success.
With Mozilla no problems.
https://bugs.chromium.org/p/chromium/issues/detail?id=1036367
First click the "Sign in" link on the upper right to sign in with a Google identity, then click the
It could also be helpful to know the model of GPU you are using.
"It looks like your browser doesn't have WebGL enabled."
Is there a quick fix for this?
Any help will be appreciated it.
Mr. Rodriguez
I had to go to chrome advanced settings and turn hardware acceleration back on, which I had set off. Works fine now!
