The project is a scooter build
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
I am trying to extrude a line to create the neck of the scooter, the line can be seen to the front. The extrusion will be in the shape of a square to create a square neck. The neck is to be at 45 degrees so should the line be. My concerns are I) is this the right approach? 2) if 1) is true how do i get a 45 degree line at the midpoint of the tip?  Please help.
https://cad.onshape.com/documents/fddd3b3610f0c9cd2a5fb4e1/w/ba9a9f617223840b201f89d3/e/dd2ab1326be2527e5bafe98c
