Improvements to Onshape - March 8th, 2021
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221 image
edited March 2021 in New in Onshape
This month everyone is busy at Onshape gearing up for our FIRST EVER Onshape LIVE Conference on March 11th! Here is an overview of what you can expect during the conference. Our developers have also been busy;  this month we are releasing a number of highly requested features. Let’s take a look!
CAD IMPROVEMENTS
BOM TEMPLATES
Company administrators can now create a template of their Bill of Materials customization that can be applied to future assemblies. BOM Templates are immediately available to everyone in your company and the default BOM Template can be set in your company settings.
https://onshape.wistia.com/medias/k49g00mt4a
PERFORMANCE ADVISOR
You'll find a new Performance Advisor feature that helps you to better understand factors affecting performance in the Document.
https://onshape.wistia.com/medias/g6zdnykvvk
CALLOUT GROUPING
You can now group Callouts with Notes, Bend Notes, Hole Tags and GD&T symbols.
https://onshape.wistia.com/medias/vmdnl7mpwq
DRAWING PERFORMANCE IMPROVEMENTS
Performance improvements have been made to adding annotations to drawings in Onshape. These changes improve interactivity when adding annotations to drawings with a large number of edges.
https://onshape.wistia.com/medias/rajbkl8qut
REVISION TABLE IMPROVEMENTS
You can now change the Date Format for columns in a Revision Table.
MOBILE IMPROVEMENTS
VIEW-ONLY TOOLBAR FOR ANDROID
You will now see a View-only toolbar when opening View-only Documents on Android devices. This toolbar makes a Document easier to navigate for those that are not experts.
    BOM Templates! that will make life easier.
    Also, I like the performance info and drawing updates.
  • EvanReeseEvanReese Member, Mentor Posts: 2,789 PRO
    BoM templates are going to be handy. I also like the step toward better performance understanding. Hopefully this leads to better understanding of what else is rebuilding besides the active tab and if/how that affects rebuild time too.
  • gerhard_swanepoelgerhard_swanepoel Member Posts: 29 PRO
    Great improvements this round. Especially dimensioning with lots of edges. BOM Templates also useful and I like the grouping feature.
  • Hans_Ole_LeirvikHans_Ole_Leirvik Member Posts: 83 PRO
    Good stuff,
    but for dates in Revision table, I didn't see the European style with: Day.Month.Year (dd.mm.yy or dd.mm.yyyy )
    Maybe its there when I try it ....
  • Effendi_HEffendi_H Member Posts: 19 ✭✭
    Finally! BOM template come. Thanks developer team.
    Thanks,
    Effendi H.
  • Alban_SemondAlban_Semond Member Posts: 1 PRO
    Good Job for BOM template.
    Thanks you
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 473 PRO
    BOM Templates! Thank you   :)
  • Josiah_HarthcockJosiah_Harthcock Member Posts: 57 PRO
    Great!
    Thank you!
  • MichaelPascoeMichaelPascoe Member Posts: 2,765 PRO
    Thanks Onshape team!
  • BMcGaffeyBMcGaffey Member Posts: 29 ✭✭
    Amazing update, BOM templates look great.
    Great stuff!  Thanks Onshape team!
    www.accuratepattern.com
  • GlendonKuhnsGlendonKuhns Member, csevp Posts: 40 PRO
    Nice set up updates!
  • jack_anderson443jack_anderson443 Member Posts: 1
    very nice update guys! this will certainly help in the near future! :)
  • fnxffnxf Member, User Group Leader Posts: 145 PRO
    Awesome set of updates- don’t even know what I should highlight! Thank you!
  • ian_d_gardinerian_d_gardiner Member, User Group Leader Posts: 35 PRO
    Drawing speed noticeably better. BOM templates...super. Thanks!
  • david_mcmahondavid_mcmahon Member Posts: 37 ✭✭✭
    Can users of all Onshape versions (inlcuding the free plan) create BOM templates?
  • kevin_elliottkevin_elliott Member Posts: 8 PRO
    Nice update! Any chance the date format default can be changed to the user preference?
    Unless I am missing something, the new BOM templates feature does not appear to be available in the Onshape free version. Is that correct?
  • danny_paynedanny_payne Member, User Group Leader Posts: 41 PRO
    Great improvements. Please keep up the great work on the drawings.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 567 image
    @david_mcmahon Correct.  BOM templates are created/managed/consumed as company level controls, so available in the Professional and Enterprise plans.
  • Mazie_HouchensMazie_Houchens Member Posts: 36 ✭✭
    Nice! Excited for the BOM Templates and Performance Advisor
