Fix Parts In Assembly
Hi
I got imported stp file of a bearing.
when it's translate to part studio, i get 11 different parts. they are not connected, but they float in the air.
I tried to put them in assembly and fix all the parts, and then us it as one part.
but when i put assembly with fix parts in a new assembly, all fix parts are moving free without relation to each other, and not as one part.
How can i fix the bearing, that it will behave as one part ?
Thanls Gilad
Thanls Gilad
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 665
Use the group feature. When instances are grouped, they will not move relative to one another based on the positioning they were in when grouped.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com6
To do this, select parts from part list, RMB click for menu - select boolean. It should open boolean dialog with the parts already in list and Union is default - this will combine multiple parts into one part.
An example of a not-so-obvious consequence of this: if a ball bearing is modelled with the balls exactly coradial with the raceways, the balls will touch the raceways only along a single line, and a Union will not unite them.
