Adding Dimension to an ellipse
IsleofGough
Member Posts: 26 ✭
in Drawings
I am learning Onshape and tried to recreate a simple hemostat. The template (sketch) for the hemostat has an ellipse. When I come to creating a drawing, the dimension tool does not seem to work on the ellipse. What I would like is the width and length of the ellipse. How is this done? Thanks.
RENDERCAD
RENDERCAD
- Can't use the sketch option in an assembly drawing.
- The drag approach seems to snap to weird places.
You might be able to use the Shift-q keyboard shortcut to select quadrants of an ellipse from here
https://forum.onshape.com/discussion/6010/how-does-one-dimension-an-ellipse-in-drawings
My design is a swept feature around an ellipse, and all of these options seem to work in the minor axis, but not on the major axis.
