How does one dimension an ellipse in drawings?
michael_mcewen
OS Professional Posts: 78 PRO
in Drawings
In drawings, I can use the "line to line" dimension tool on a section of the ellipse, but there are no points to drag dimensions on an ellipse in plan view. I've tried every tool. Any ideas?
Thanks,
Michael
Thanks,
Michael
john_mcclary
Member, Developers Posts: 4,043 PRO
No I just don't use the vertical line at all. I showed that to show you it will extend beyond the geometry, giving you the 0.90"
See the first post, where I used the 2 horizontal lines. When you mouse over the top of the ellipse you will see a diamond, representing the top quadrant of the arc.
Then project that line horizontally to the left / right and click when you see the X appear near a dotted line.
I don't have video recording software installed at work, so best I can to is type it out1
OS does not allow dimensioning to hidden lines. period.
https://cad.onshape.com/documents/3a02151ecb45d32215736cb6/w/2599429d396906bb4978c958/e/1d5ddf3757a685da951e8369
Thanks,
Michael
so making 2 horizontal lines instead will achieve what you want
Don't forget you can also press Shift Q when in the dimension command (providing the ellipse axis is horizontal/vertical)
Nice I didn't notice that shortcut
Here is the list by the way.
https://forum.onshape.com/discussion/5920/improvements-to-onshape-march-2nd-2017#latest
The magic answer is SHIFT-Q
This will activate the quadrant points that you can dimension to
