Surface from solid
viktor_paile
Member Posts: 3 ✭
Hello, here's this noob's question 1:
Is there a way in Onshape, or indeed in FeatureScript, to retrieve (or query for?) the surface of a given solid? Say, get a spherical surface from a given solid sphere?
- So little time, so much to know!
FeatureScript 1472; import(path : "onshape/std/geometry.fs", version : "1472.0"); annotation { "Feature Type Name" : "test" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "body", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 } definition.body is Query; } { const faces = qOwnedByBody(definition.body, EntityType.FACE); debug(context, faces, DebugColor.RED); });RENDERCAD
Also, if you search the forums for "new custom feature" you will find most of my features. Some of the earlier ones have nice notes for someone starting from scratch.
RENDERCAD
