How do I make my shape hollow?
meg_brown
Member Posts: 10 EDU
Hi there,
I am trying to make my shape hollow, but it says that it did not 'regenerate' properly.
How do I fix this??? I would super appreciate se help!
These are the problem areas you may want to cut away these walls hhen hollow then add them back in with split and boolean
https://cad.onshape.com/documents/233a0504394d24b3a4fb5bd3/w/e3f98cbec63c9775317803b6/e/4ef6c38cb4c9b549ee8e638d
https://cad.onshape.com/help/Content/sharedocuments.htm?Highlight=sharing a document
I have adjusted the sharing settings, so I hope this should allow you access. The new link is below:
https://cad.onshape.com/documents/340272529a46000e8cf6a1fa/w/97db2afceb3a20024acd9774/e/6438b56fefe4db5fdc49724e
Are you sure about the size??
And I think it is much easier to import an image into a sketch and trace the image in Onshape, and with entering the first dimension the total sketch will resize to the proper dimension.
https://cad.onshape.com/documents/d9cb6acbb41af6183bd90978/w/332c426c87b8fefffe9bf6c5/e/09d0b05fac01f5a6662c59bd
