Creo Zip file not converting
jmccormickjmccormick Member Posts: 40
To get an assembly from Creo to import into Onshape, I need to provide a zip file of the assembly.   However, when I do "File>Save As" in Creo 6 then select the type "Zip File (*.zip)", I get an error from Onshape import saying "... Ensure zip file name matches root assembly name..."
From Creo, the zip file is named the same as the assembly by default.  What do I need to change in order to get my Creo 6.0.6.0 assemblies to easily import into Onshape?  Opening a Creo assembly directly in Onshape did not work either.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,035 PRO
    I had more trouble than it was worth and had the best success exporting my Creo 6 assembly files as STEP, then importing them into Onshape. To directly answer your question, I believe if your assy file is named A1000.asm, then your ZIP file would be named A1000.asm.zip. I think you need the .asm in the zip title name. Its been a couple months since I moved all my Creo 6 to Onshape so I may be misremembering.
  • jmccormickjmccormick Member Posts: 40
    Hi, @nick_papageorge073.  Yes, that is how the zip file name is formatted by default.  The zip file is actually saved as asm0001.asm.1.zip.  I tried to remove the version part of the name (.1) but that didn't work either.  I guess STEP files it is, then...  (The files are probably converted to STEP during the import part anyway.)
    There have been so many things to figure out for this migration.  It is turning into a nightmare.  Any other "off-the-cuff" advice for the migration will be more than welcomed.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    Should be named asm0001.zip
