Can I use a variable in the quantity field of a circular pattern ?
brian_sweetbrian_sweet Member Posts: 12
I have a sketch, and am using a circular pattern.  I have diameter variable for the size of the ring.   Depending on the size of the ring I may want to increase/decrease the count of the pillars on it.
I have created a variable name #Num_Bars as a number but it will not accept it.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,923 image
    Not possible. This should be done using a feature pattern.
  • brian_sweetbrian_sweet Member Posts: 12
    I will git that a try
