Why is it so and how can I fix it,
charlie_aaquilina
Member Posts: 3 ✭
I recently started to use Onshape. Making plans for a letter box, Sent my DXF to the cutters, whose response was WHY is your letter box 32mt tall.
Checked my units settings (OKmm) checked my file with eDrawings to find the 32mt tower.
So what am I doing not right
THANKS anybody.......................
NeilCooke
Moderator, Onshape Employees Posts: 5,984
They need to set the units on their software when they import, as the DXF file format is unitlessSenior Director, Technical Services, EMEA0 -
dirk_van_der_vaart
Member Posts: 561 ✭✭✭
Never had problem's about unit's when you export directly from a planar face, like this
Dimensions not correct when exported from OnShape — Onshape
