Anchor a Feature to the Bottom of the Feature Tree
Sometimes I have features in my model that absolutely always come last like rotating a model to make drawing creation easier to adding draft of fillets to a part. It would be interesting if I could right click on a feature and select "keep anchored to end of feature tree" or something similar. That way I don't have to remember each time I add new features.
The highlighted feature here rotates my part so that my draft direction is parallel to the front plane.
Is that not what named views will do? Named views maintain position regardless of feature tree and can be changed later if needed.
When making the drawing simply select the named view and other projections from it will follow. Of course you can have more than one named view.
Still, not to discount your request, maybe it can be a useful workflow in Onshape?
Understood if this is hard to do, Lou!
