Move Face Translation Using Vector Addition
Kyler_Walker
Member Posts: 211 PRO
I am moving a face by some amount in one direction and some amount in the orthogonal direction. I would appreciate if I could, in the same feature, move in multiple directions. I would propose treating the resultant move as the vector sum of each magnitude and direction pair. This would help reduce the number of features I need.
Although this would be possible in a custom feature, most use cases are not adding different vector transforms per face. This could be done with an array parameter however if you are doing offsets, this is possible due to the implied direction. One thing that can make this more complex is from a troubleshooting standpoint when you have nested properties like this and you are hunting down what has moved a face a specific direction.
I am interested in understanding your process here.
