trying to control the curvature of loft
EvanReese
Member, Mentor Posts: 2,676 PRO
If I mouse over the failing loft feature, I see this error message
that means that the guide isn't exactly on the loft profile curve, even though it looks like it. Sometimes it could even be due to the tolerance limits of the CAD system (it's not infinitely precise). To fix it, make sure to use the "pierce" constraint in the sketch between the curve end points and the loft profiles. That fixes it.
2
ghg | Part Studio 3 (onshape.com)
