Can one control the time to automatic logout?
Is there a way to specify how long an inactivity while logged in will automatically require a new login? It happens too often to my taste, but could not find such a setting in my account/security settings...
If you want to fake activity or prevent an log out on an open tab, you can select a face of any part. that will send a signal to the Onshape server which resets the idle timer.
Sometimes you may see an early log out, even if you are currently working. that is usually summed up as an internet connection issue, or a browser crash.
