How do I insert dimensions in a pyramid correctly?
frank_ring
Member Posts: 38 ✭✭
in Drawings
Hello,
I am trying to make a simple example drawing with this part (plywood, 18 mm) which has a slope on the pyramid of 15°.
How can I correctly measure the plane A with the cutting plane B in this drawing? Essential for manufacturing. In reality this is not 90°!
Thanks for your help!
Optionstim_hess427 Member Posts: 648 ✭✭✭✭You're seeing inaccurate measurements in your drawings because you're parts are not aligned with the default views (Top, Left, Front, etc...). What you can do is go back to the part studio and create "named views" where each part is aligned appropriately for your drawing. You should only need one per part.
Then, you can insert these named views into your drawing and create projected views from them.1 -
Optionsbruce_williams Member, Developers Posts: 842 PROHi @frank_ring
try normal (shortcut key ‘n’). After selecting surface. Or for more control add a mate connector and normal to the mate connector. With the creation options including move/rotation allows precise orientation of mate connectors. They act as extra coordinate systems.www.accuratepattern.com0
Is there a way to set the view exactly to one surface?
In the meantime I found this useful instructions.
https://www.onshape.com/en/resource-center/tech-tips/tech-tip-using-named-views
