Document is slow on one computer but not another
ednamodeednamode Member Posts: 5
I've resorted to using my laptop because my desktop's onshape experience has become so slow. I've cleared cache, updated, restarted etc. The browsers between my two machines are exactly the same (same plugins as well). I can't think of any hardware bottlenecks that would cause this to occur (high power GPU, gigabit ethernet, modern and powerful CPU).
The slowness occurs anytime I try to change the document. The interface hangs and I get a spinning blue circle. Anything else I should try?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
  • ednamodeednamode Member Posts: 5
    If I'm not interacting with the document it runs very nicely. If I start sketching though, the entire interface hangs.
    Is it the same on a different browser?
    No. Using Edge speeds it up considerably.
