the hardware requirements
for the Onshape Team
dear Developers
why chapter Hardware and Graphics Performance Recommendations does not contain a table like this
3d model/assembly complexity | hardware requirements
for examle
< 173000 spline surface | CPU: a'la Pentium II
or < 592007 instances in | RAM: 512MB
assembly | graphic card - GPU a'la GeForce 3, RAM 128MB
perhaps this information is located another place...
Paul_J_Premakumar Member, Onshape Employees Posts: 230
Hi @ Alexy_Kougerman,
This is a good question. I'll take a look at the page and see we can make improvements to it.
I don’t speak for the entire Onshape organization, but as a developer there are a couple of reasons why we don’t have a table like the one you ask for:
1. Too many variables: Onshape is designed to run on different OS, CPU, GPU, Browsers
Unlike traditional desktop applications Onshape runs on a lot more configurations. To be of any value we need to create a table that involves all these different configurations. Our focus has been to give you the best possible performance on any given platform.
2. User requests / Priority
Our advice to users has been to try Onshape out on the platforms of their choice. With Onshape this is easier to do, because you don’t need to install an application to test it out. Most users go this route or turn to the forum.User requests helps us prioritize features. You can create an improvement request to get information to be published, this will help us.
Lastly if there is something impeding your work, please contact support, they will be able to guide you.
Paul
3
From a pure rendering standpoint, the best recommendations I've seen are to just get decent gaming type graphics cards. My models are moderately complex and I have no issues with a really low-end graphics card in my laptop. The models are work-able with integrated graphics, but just a little slower.
you said: "to search the forums here for different people's reported experience"
in that case why here the Developer does not provide information "for all questions about the hardware, depending on your tasks, please contact the forum"
you said: "... your internet speed and latency ... the use of patterns, variables, linked documents, derived features, etc ..."
that is, the main criteria are listed and if their sizes/values will be linked in some way with hardware, it will be great
I know for sure the hardware for modeling a car is suitable for modeling a manual meat grinder and the hardware on which you can still draw a meat grinder is not suitable for cars
by the way, about Internet Connection the Developer writes: "... it does not require constant use of a high bit-rate"
high bit-rate? what is it? how many?10Mb/s, is it high bit-rate? but may be 50Mb/s is high bit-rate?
you said: "... decent gaming type graphics cards ... a really low-end graphics card ..."
as well as the Developer: "... you don't need an expensive graphics card, a low-end gamer card ... More GPU RAM will enable more ..."
decent, really low-end, expensive, more GPU RAM - what is it? how many/much?
@tim_hess427
thanks a lot for your trying to explain ...
but I'm curious if the Developer (dear Onshape Team) has anything to say about this point
This is a good question. I'll take a look at the page and see we can make improvements to it.I don’t speak for the entire Onshape organization, but as a developer there are a couple of reasons why we don’t have a table like the one you ask for:
Paul
I quite see
thanks
this
is my case
my task is creating 3d model of light airplane
and bellow is my hardware walking:
CPU 2.2GHz(2 cores); RAM 2GB
for
for
and now I see that it needs to upgrade my hardware
yes, I will contact support for advice on additional settings or upgrading
