add drawing
ehsan_pazookiehsan_pazooki Member Posts: 52
Hello guys,
could some one tell me how can I add and creat drawing from a 3d model? Onshape is a litle bit changed.
thank you
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
  • jake_delano19jake_delano19 Member, csevp Posts: 19 EDU
    Hello @ehsan_pazooki, check out our Drawing Basics article in our Help Center, it will teach you all about creating drawings directly from a model
  • ehsan_pazookiehsan_pazooki Member Posts: 52
    Hello guys, I hope you are fine. Thank you very much for you answers but I don't see the plus sign. I havn't worked with Onshape for a long time. My account was expired but I opened it again. At that time the Logo of Onshape was blue, but not green, and I could see the plus sign on the down side. Right now I can not see the plus sign. Please help me.
    You do not have edit permissions to that document - ask the author to change your permissions.
    thanks. Im the author. How can I ask my self ?
    Sorry, to much questions ... =)
    You are showing the "Simplified UI" associated with read-only documents, so you are either not the author or you have previously had a paid or EDU subscription and allowed it to lapse. In that situation, documents become read-only.
