Create a mesh
I designed a Klein Bottle and I would like to create a mesh from it. You can see the result I want to achieve here: http://www.thingiverse.com/thing:910737
You can see my model below and I made it public so that you can play with it here https://cad.onshape.com/documents/d7c86b5627294c37b96f2b2a/w/772c5edf6c014f83908872e4/e/398dc3450b15406eb0c069b2
Does anyone have a clue how to do such a mesh in Onshape?
1
Step1. Create the sketches you want to project in an offset plane then use the extrude command (surface) with the up to next option.
Step 2. The last time I did this to probe the concept I left the surfaces and worked in the resulting projected curves, when done I hid the surfaces; this time I used the split command between the part and each surface (It does not generate any additional parts, I get an error message for closed surfaces but it does the trick "Selected entity does not split the part")
Step 3. Perform some limited operations in the projected sketches. in the case below only thicken and sweep worked.
¹ https://cad.onshape.com/documents/d7c86b5627294c37b96f2b2a/w/772c5edf6c014f83908872e4/e/398dc3450b15406eb0c069b2
It has been flagged and is being worked on.
ON EDIT: I used to sometimes use this method in preference to "sketch to sketch" even when the latter was available, because it can be hard to visualise what's happening with the former.
Surface extrudes are very explicit and WYSIWYG, especially when the result is topologically ambiguous or impossible.
So the workarounds are valuable diagnostic techniques at the very least, and well worth mastering and remembering, it seems to me.
Hi everyone, I am new to Onshape,
I was looking for the same application and found the command "grid extrude". It does not have Voronoi shapes, but it is powerful. The next video could help: https://youtu.be/a5B2pF6iZRg?si=-iNY1iefqSfTDwwy.
Also coul be interesting this Voronoi generator https://voronoi-editor.web.app/%2C for using with wrap command o maping a surface. I hav not used yet but I will share you results if I have it.
Hi, I found this thread when working on my Voronoi face lattice FeatureScript, thought it might be of interest here.
I'm right off the bat not sure how to approach the Klein bottle example, but I'll give it a shot.
See more here:
