Non linear pattern - featurescript needed?
frank_ringfrank_ring Member Posts: 44 ✭✭
I should generate a non-linear pattern where each distance is increased by a value (variable). E.g. first distance: 10 mm second distance 10+5, etc., where the "5" could be a variable.
The result could look like this: 0 - 10 - 25 - 45 ....
Is there a featurescript which does the job?
