Non linear pattern - featurescript needed?
frank_ring
                    Member Posts: 42 ✭✭
            I should generate a non-linear pattern where each distance is increased by a value (variable). E.g. first distance: 10 mm second distance 10+5, etc., where the "5" could be a variable.
The result could look like this: 0 - 10 - 25 - 45 ....
Is there a featurescript which does the job?
NeilCooke
                            Moderator, Onshape Employees Posts: 5,912
                    See second video here https://forum.onshape.com/discussion/2675/improvements-to-onshape-february-11th-2016/p1Senior Director, Technical Services, EMEA1 -
alnis
                            Member, Developers Posts: 452 EDU
                    @NeilCooke great video!
@frank_ring the short of it is that the second variable definitions are defined as #previous_value + some_number, so each time the feature is evaluated in the pattern, the variable is incremented. By including the variable update features in the pattern, the variables are changed on each "loop" through the previous features, driving the interesting spacing. Let me know if you'd like some more clarification!
Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.0
- Define variable(s)
 - Features depending on variable
 - Update variable(s) as a function of their values
 - Pattern features 2 and 3 with apply per instance enabled and zero distance
You can get the result you want. Alternatively, if you want a math function, I'll often define a variable of the number type and increment it by 1 each "loop," then having variable values calculated from the input. Here's an example showing how to do it with a face, feature, and part pattern:https://cad.onshape.com/documents/b36835e0b8c5c0ae67603156/w/e055f55f4098317ec7891d23/e/af25df1e4390c6076a7062f8
To quote Thanos:
@alnis_smidchens - Genius
I did not know Onshape could do that!
Maybe you can explain it in this example.
