How to Have a onshape soildwork file come up on E drawling
grant_woods922grant_woods922 Member Posts: 2
When I explore a file I have to export it as a solid works file but when I would go to open the file upon E drawling it said that it is not compatible
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,930 image
    eDrawings requires the tessellated graphics to be stored in the SLDPRT file. Onshape only stores the Parasolid data since that is all SolidWorks requires. Why not just share the Onshape doc instead of sending an eDrawing?
    To make it work with eDrawings, open it in SolidWorks then save it again.
  • mahirmahir Member, Developers Posts: 1,319 ✭✭✭✭✭
    If you don't have SW handy and you want another option besides sending an Onshape link, eDrawings can also open several other export types directly (e.g. Step, Iges, Parasolid).
