Undo "Restore to Main"
kvdmolenkvdmolen Member Posts: 26 ✭✭
edited May 2021 in General
Hello,
I have accidentally clicked "restore to main" when viewing a previous edit.
Now it seems I have lost all the work since then.
Is there a way to retrieve these edits?
PS. Seems to me it is very easy to make this mistake. "Restore" could also mean "go back to". Perhaps a warning would be nice?
Thank you!
Klaas van der Molen
This is my private document: https://cad.onshape.com/documents/c466641a0077ecb580717733/w/1caa2664aee159990719775e/e/f7cf36054b66637fef487b0d
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,843
    edited May 2021
    Yes, you should be able to just restore the entry directly below your Restore to Main action:
  • kvdmolenkvdmolen Member Posts: 26 ✭✭
    @NeilCooke I don't really understand what you mean:
    I have clicked "Restore to Main" from viewing a previous edit (not a version):
    Where I should have clicked "Return to Main"
    but now all the edits after this edit are not visible anymore in my history.
    I only see the restore-action in my history:
    Any way to retrieve these lost edits?
    The difference between the two buttons is huge if all edits are actually gone (when not created versions).
    PS. only for future reference, I have already created a copy and moved on. The screenshot is from the original file.
    Thanks,
    Klaas
    No edits are ever lost - in this instance, right-click "Assembly 1::Drag:instance" and "Restore to Main"
