Circular pattern Problem
nicola_malagnininicola_malagnini Member Posts: 35 EDU
edited May 2021 in Community Support
hi,
as you can see in the video. there is a problem. when i try to do a circular pattern of a hole, i can't extrude holes that results. and the hole that i extrude before, now is full.
where is the problem?
https://youtu.be/DxXpVnZ3wtI
thanks
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,980 image
    Change it to Feature Pattern (currently set to Part Pattern)
  • nicola_malagnininicola_malagnini Member Posts: 35 EDU
    Solved!
    Thanks!
