Show sketch created with a feature in a drawing
monroe_weber_shirk
Member Posts: 103 EDU
I am able to show a sketch that I've created in a part studio in a drawing.
However, if I create a sketch using a feature, then that sketch isn't in the available list of sketches associated with a part studio.
How can I insert a sketch that I create with a feature into a drawing?
One workaround you could try is to manually create the sketch you want before you create the feature. Then, inside the feature, you can copy all the sketch elements into the feature sketch with "use".
