Drawings doesn't show sketches made in custom features
monroe_weber_shirk
Member Posts: 103 EDU
I'm wondering what sketch property is being used by the drawing to query the sketches and exclude the sketches created by custom features. I created a custom feature to produce a sketch for use in Drawing and am unable to find a way to get it into the Drawing. I'm guessing there is a sketch property that is set to a different value for sketches created by custom features. What is that sketch property and can I change it so my sketch is visible to the Drawing?
NeilCooke
Moderator, Onshape Employees Posts: 5,983
Unfortunately no.Senior Director, Technical Services, EMEA0 -
EvanReese
Member, Mentor Posts: 2,864 PRO
Your feature could use opExtractWires to at least make curves (like the Composite Curve feature), and if there are more than one curve, you could use opCreateCompositePart to make them a single composite part you can add to the drawing. Obviously this would be a bit of a workaround.0
