Convert column in imported CSV to a user selectable list
Title says it all. Just can't figure out how this is done. CUSTOM SHEET METAL FEATURES | sheetMetalStart.fs Copy 1 (onshape.com)
Thanks so much if you can provide an example or point to one.
NeilCooke Moderator, Onshape Employees Posts: 5,859
Sorry to lead you astray there @Alex_Kempen but all user interface components must be static so nothing can be done on the fly.What I was referring to was some sort of external parsing code that could convert csv into a map suitable for a LookUpTable. You would then have to copy/paste the resulting text into a separate Feature Studio and reference that in your feature. So if the csv changes you would have to update your feature each time.Senior Director, Technical Services, EMEA0 -
shawn_crocker Member, OS Professional Posts: 889 PRO
NeilCooke said:Sorry to lead you astray there @Alex_Kempen but all user interface components must be static so nothing can be done on the fly.What I was referring to was some sort of external parsing code that could convert csv into a map suitable for a LookUpTable. You would then have to copy/paste the resulting text into a separate Feature Studio and reference that in your feature. So if the csv changes you would have to update your feature each time.0 -
yeah the second one unfortunately.Senior Director, Technical Services, EMEA0
Thanks. I will have to do some experimenting with reusing existing code and just creating a new interface. For the time being, I have just created an enum that matches the values in the csv. It works OK for me but my secondary goal is to have a feature that other people can use without having to dig into the code to use.
2.5 years later and I am finally revisiting this.
The error looks like this:
Any guidance on this would be great. Being able to reference a csv to drive a list of options would greatly streamline some features I have cobbled together.
