Drawings doesn't show sketches made in custom features
monroe_weber_shirk
Member Posts: 96 EDU
I'm wondering what sketch property is being used by the drawing to query the sketches and exclude the sketches created by custom features. I created a custom feature to produce a sketch for use in Drawing and am unable to find a way to get it into the Drawing. I'm guessing there is a sketch property that is set to a different value for sketches created by custom features. What is that sketch property and can I change it so my sketch is visible to the Drawing?
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,417Unfortunately no.Senior Director, Technical Services, EMEAI0
OptionsEvan_Reese Member Posts: 2,066 PROYour feature could use opExtractWires to at least make curves (like the Composite Curve feature), and if there are more than one curve, you could use opCreateCompositePart to make them a single composite part you can add to the drawing. Obviously this would be a bit of a workaround.Evan Reese / Principal and Industrial Designer with Ovyl
Website: ovyl.io0
Website: ovyl.io
