Throw some red coloring on mates which have missing mate connectors
Eric_WongEric_Wong Member Posts: 24 PRO
edited August 2021 in Product Feedback
When a mate connector in a mate has an error, the mate itself should turn red so that I don't have to go opening up all the mates to see which one is causing the mate error. See attached pic. The slightly lighter shade on the broken fastened icons is difficult to understand, and in scenarios where there aren't dark fastened icons to contrast them it becomes way to hard to see what the source of the mate issue is without opening all the mates individually.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @Eric_Wong Can you show me an example?  IT seems there is more to that mate feature list than I can see.  Are you saying one of the mates has a failed selection? Can you show me the failed case?
