Introducing Camp Six: an Onshape-based frame design and ordering system (seeking beta testers!)
in General
Fellow Onshapers! After months of using this forum's incredible experts to answer countless questions, I hope at last to return the favor. I'm delighted to introduce an Onshape-driven experience to rapidly design and order custom metal frames.
Using our Featurescript collection (still in closed beta), you quickly sketch your frame as a wireframe mesh, and then we compute all the 3D details (e.g. tube coping and joinery). We rapidly make the elements of the frame on our custom CNC plasma/welding machines (it feels like 3D printing, but with steel!). We flat-pack the elements, ship them to you from our warehouse in Santa Cruz, California, and you can assemble it with simple tools.
This is a very nice alternative to 80/20 in many cases (much cheaper, and no measuring/cutting required), especially where the geometry gets non-rectilinear. The whole point of the system is to help engineers and designers build faster.
Check out www.campsix.com to see what we've made so far, order demo products, or request a quote for rapid turnaround custom work!
6
Your products are really nice!
I'm curious about the strength of the joints since they're different from traditional welded tube joints and 80/20 type frame joints. Some sort of benchmarking would be neat to see. If nothing else, it would help designers to have a better understanding of the capabilities of the system.
I'm thinking about use cases in automation equipment or test equipment and I can see lots of scenarios where you build a machine and then realize later on that you need to add an extra sensor or something. This is pretty trivial with 80/20 type systems, but it would be a different challenge when dealing with round tubes. At least with square tubes, it would be fairly easy to drill and tap a hole quickly.
Excited to see how this goes! Good luck to you guys.
