Seeking eyes on this design! (Total Newbie)
elizabeth_schmidt
Member Posts: 5 ✭
Hello!
I'm in an ENGR 101 class and our final project is to design a desktop organizer. Our teacher did a sink or swim sort of thing to see what we could teach ourselves about the program, and I think I'm doing pretty good for having not really touched it before.
However, we have to set it up for laser engraving and I'm not sure how to make the tabs, other than manually adding them one at a time, and subtracting them, is that the right way to do it?
Does anyone see any real obvious mistakes on this? I wasn't sure how to make it a solid piece, so my idea is to glue the left and right parts together. The flap *should* have the ability to pull up and expose the inside of the box...
Here is my design:
https://cad.onshape.com/documents/75db4c2837e7d077bd9e40cb/w/f91d9bc401bba767a2b882a6/e/857f73a15bbbf131dcf834a8
Thanks, friends!
I'm super excited to join this community and learn more!
Here is my design:
Thanks, friends!
I think this looks pretty good for a first time! A few thoughts come to mind:
In this case, you're looking for my suite of laser-cut design tools, Laser Joint, Kerf Compensation, and Auto Layout. @alnis_smidchens did a brief video tour of the joint FS, here:
If you do decide to use these tools you'll need to change how you're doing the actual modeling a little to meet the prerequisites for the features, but nothing too drastic.
I realize now I'm gonna have to make each "face" of the box separate, rather than an extruded shape....arugh. Back to the drawing board.
Thanks for the note on the front tab, I'll shorten it on MK2.
It's gonna be sent to a laser engraver in the schools shop.
check out the Split command which will aid in creating separate panels.
