How do you switch the direction of a butt joint in Beam feature?
I recently added to Beam feature to my Onshape interface and it is a great tool. In all the instructional videos I have seen on this feature you switch the direction of a butt joint by dragging an arrow that pops up next to the vertices. In my case the arrows don't appear which keeps me from changing the direction of the joint. If anyone knows why the arrows are not visible when I create the butt joints that would great.
Example: https://cad.onshape.com/documents/eb025d912c15d30c7b734756/w/6d55e6ead4f95cde5e4915f2/e/6148819802c61d3afd7fc147
The butt joints are "coped" but that is not the desired outcome, even with cope deselected.
No flip arrows at the vertices for the butt joints.
