Scroll bar for document tabs.
Alex_MAlex_M Member Posts: 2 PRO
A horizontal scroll bar for document tabs would be nice, rather than using the arrow buttons or pulling up the tab manager.
  • alnisalnis Member, Developers Posts: 452 EDU
    Not quite a solution for your problem, but Alt T opens the tab manager, which can save some time so that you don't have to move your mouse as far
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,958 PRO
    edited June 2021
    I agree, the alt+t tab manager is my only method hunting for tabs.
    It has search, sort, filter, view by thumbnail, easier to visualize as it is in a tree layout.
    I mostly forget the bottom tabs even exist to be honest, unless i'm exporting or viewing the properties of the 'current tab'
    Mouse wheel also works on element tabs.
