Extrude cut - can't cut through the whole part body?
nick_demarco330
Member Posts: 8 ✭
I'm coming from Solidworks, where I can sketch on a plane, then cut-extrude through a body, including through gaps (like cutting a hole through all fins of a heat sink).
In OnShape, I'm not getting this to work. The part is here:
I'm trying to cut Extrude12 all the way through the part (making a vee relief). I'm not understanding why the cut doesn't propagate beyond the first solid element.
If you make the model public then we can probably be more help
I did change the extrude remove from bind to through all because that's what I wanted to do - cut a sketch through all the surfaces.
@Alex_Kempen, did you look at the part? It is a single body, single part.
I tried some other things after posting this. Since, I reverted the feature. Screenshot below.
Changed sketch to be normal to world (on mate connector rotated off bottom) and works fine. (see below)
