Can't interact with view cube?
david_blackmandavid_blackman Member Posts: 4
Hey all,
Somewhat new to onshape, but I've consistently been having a problem where when I click and drag on the view cube, I imagine that the view should rotate with me but instead the view cube just moves around the screen. Is that expected behavior? I'm seeing it in different browsers.
Thanks,
David
  • alnisalnis Member, Developers Posts: 452 EDU
    Use the same button you use to rotate the view normally to rotate using the view cube. By default, this will be the right mouse button.
  • david_blackmandavid_blackman Member Posts: 4
    So does it not work at all with a macbook trackpad? neither option-click nor two finger click works
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,865
    Yes I use it all the time - rotate is click-drag right mouse button, so on a trackpad you can set it to be click-hold-lower-right-drag-with-other-finger or as I have it which is click-drag-two-fingers. And please ignore the view cube top right, just drag in the graphics area.
