How to remove channel on cylinder
steve_pearson561steve_pearson561 Member Posts: 7
There's got to be a simple answer to this but I just can't figure it out.
I need to cut a half-circle around the outside of a cylinder. I think I need to use the sweep command because I need to follow a path.
Here's an image of how I would like the channel to go:
This is very easy on a rectangle but can't get it to work on an extruded cylinder
Thank you for you help,
Steve
