F2 for rename
Please make the F2 button invoke Rename ... this is so universal, and it's driving me nuts I have to rt-clk or remember Shift+n.
F2 is not reserved see :https://www.w3schools.com/tags/ref_keyboardshortcuts.asp
or https://css-tricks.com/snippets/javascript/javascript-keycodes/
Btw. n is a nasty shortcut as it opens new window if ctrl is accidently used.
Is the problem that F2 might be used for other things on some computers/browsers? Some keyboards do map all the F keys to "nifty" special functions by default :S .
I liked to stick to using F2 once I discovered it because I am not a fan of 'slow clicking' a file to rename it. So it became natural to try F2 in other programs that have objects that can be renamed. Such as SolidWorks tree items for example. Onshape being developed by the same staff should have caught onto this shortcut from the start. But they also all seem to like macs for some reason so maybe they got brainwashed at some point and forgot the basic shortcuts from windows
If you want to rename a file, but only by adding or removing a character, like a symbol or a number; this is what works for me:
1. open a file
2.wait for the file to load up completely.
3.hold down shift and make a left click over the file name (that always appears to be highlighted
4.now, a part or a few characters of the name get out of the highlighted space, here make a second left click with your mouse near one of the characters that are not highlighted, and you can choose where the new character or number will be place.
5. make one last left click anywhere on the empty space of the model, and the new name gets locked back.
6.close your document, and now appears updated on your folder.
F2 for rename is available in
