How to animate a compliant mechanism in Assembly
vikram_koli595vikram_koli595 Member Posts: 31 EDU
Hello everyone, I have been using compliant mechanisms in my designs recently and have found that they are very useful. I need some way to look at how the mechanism will bend. I think a simulator might be better at this but I'm not sure. Help would be appreciated! Thanks
    alnisalnis Member, Developers Posts: 449 EDU
    You'll want to use an external simulator for this.
    In Onshape, Part Studios define the geometry of parts while Assemblies define how parts move relative to each other (so bending a part within an assembly is not possible, only inside the Part Studio). Plus, compliant mechanisms are pretty challenging to simulate.
    Unfortunately, I don't have experience with simulating compliant mechanisms, so I am not sure which software to recommend.
    Student at University of Washington | Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,908 PRO
    you may be able to use one of the simulation tools in the app store
    App Store - Onshape
    App Store - Onshape
    Thanks for the guidance! I will do my research
