Beams FeatureScript since V21 merge failing unless Properties are set
andyshinn
Member Posts: 5 PRO
Not sure if this is a bug in Beams FeatureScript. But it fails for merge sections unless properties are set. Intentional or bug?
NeilCooke
Moderator, Onshape Employees Posts: 5,979
That would be a bug. Thanks for letting us know.Senior Director, Technical Services, EMEA0 -
NeilCooke
Thanks, @andyshinn it is now fixed in V25. Looks like that bug has been there for a good while. Also took the opportunity to optimise more parts of the code to improve performance.
