Beam Feature Script Trimming Custom Profiles
When trying to use the beam feature script I need to make a custom profile angle iron of 1x1x1/8 in. When it is inserted and tell the vertices to be butt joints it will not automatically trim one of the angle pieces to be "nested" to one another. If I try and use a profile that is part of the script such as the ANSI L Equal Angle 2x2x1/8 in then it will automatically trim and nest the two pieces perfectly. Is there a way to get it to do this with custom profiles since the standard profiles is so limited?
What I want to happen (this is with the 2x2x1/8 standard profile:
What it does with a custom profile angle iron:
https://cad.onshape.com/documents/86d3bfe5788f842fe95a7e5b/w/88d762c01e18817a0a3cbd43/e/ee5d9dc67ee2e389435b2f91
NeilCooke Moderator, Onshape Employees Posts: 5,848
When using custom profiles coping is disabled by default - click “enable coping”Senior Director, Technical Services, EMEA0
