Trouble with extruding
 zach_lane579
                    Member Posts: 2 ✭
zach_lane579
                    Member Posts: 2 ✭
                                  in General
                    I am having an issue with extruding the S on this design.  I was able to extrude everything but the s and the big center of the circle.  Link below.  I am getting an error saying Extrude did regenerate properly, Check input.  It appears it is all closed
.https://cad.onshape.com/documents/c67c86c7d2d8d9e5ac3f2d40/w/627f01404534d8332f1648c3/e/3c9de18c7802dd488270acf2
looks like you fixed it?
Another topic - do you want all the components to be seperate parts. If not change the extrudes to 'add' instead of 'new'. Or boolean them together...
Welcome to Onshape and the forum.
You likely have an open sketch and the shading you see is imprinting. You can turn imprint off in the sketch dialog.
if you share a public document we can better help
see instructs here
