some possible reasons and solutions
1) the geometry may not be truly round
2) try picking just the edges
3) try placing a mate connector
4) make a sketch and trace over the perimeter with 3 point diameter circle
Hi Dylan,
Welcome to Onshape and the forum. You will find folks are very helpful here.
Please look at my original answer; there is a link to 'Read this first' post that gives instructions on sharing public doc. Yours is read only so I had to make a copy.
Next as a beginner, you should work through the lessons at the 'Learning Center' button upper right corner. The tutorials there are excellent.
For your question click the edge of wheel, it will show 1/2 highlight, then in bottom left of window, click the measure icon that has a center position. See this animation.
