how to assign a variable to control number of sides of a polygon?
dhiraj_patil
Member Posts: 3 ✭
Alex_Kempen
Member Posts: 258 EDU
Sketch patterns and polygons cannot unfortunately be controlled with variables. This is due to the way Onshape handles creating new sketch entities internally; new entities aren’t processed deterministically, so increasing the number of sides on a polygon and then changing it back will cause things which reference the sides of the polygon to behave unexpectedly and inconsistently.
One alternative to configuring polygons directly is to make multiple polygon sketches and to use configurations to switch between them.
Also, note that variables are called in Onshape using a # - this also activates the variable autocomplete menu.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots1 -
EvanReese
Member, Mentor Posts: 2,824 PRO
This limitation bugs me semi-frequently, and if the Onshape team finds a way to make it work in the background, that would be great. Until then, I'll get around it like this. Start by making a surface that's a single section of the poligon, using the circular pattern feature to make the whole shape, and extruding the face (or lofting or whatever). Here's an example.
5
