Aluminum extrusion with T or V slot Assembly
dan_schwartzdan_schwartz Member Posts: 16 ✭✭
What is the best way to build aluminum extrusion, with T or V slot?
In Part Studio assembly?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,899
    Use the Beams custom feature with a custom profile. It also has a complete 80/20 library included.
    @dan_schwartz, as Neil stated, the beams custom feature is the key to modeling structures made from extruded T-slot, tubing, and the like.  Depending on your purpose, consider modeling only the unique parts in a Part Studio.  Then create an assembly from those.
  • dan_schwartzdan_schwartz Member Posts: 16 ✭✭
    When I make Frame with T-Slot extruded, What is the way to set the corners?
    Regards
    Hi Neil
    It's doesn't work.
    Can you share a example with me?
    It doesn’t look like you selected any vertices? There is an example in the Beams document (right click the feature and “open linked document”)
