Gear function rotational alignment
Hello,
I have 2 identical 'gears', 8 teeth each that I want to mesh together. When I install them using revolute mates and then apply the gear restraint the teeth align so that the teeth are lined up with each other, rather than one tooth and one space. The revolute mate has the option to rotate the part around X and Y axes, but my CL is on the Z axis. Not sure if the issue is with the revolute mate or with the gear mate. The same part file is used for both gears, 1:1 ratio.
Bob
