Configurations of parts and quantity in BOM table
cameliacummingcameliacumming Member, Channel partner Posts: 2 ✭✭
Hi all,
I'm looking for a way that we could create configurations of a part which would be counted as the same part in a BOM table
For example - a bar that has a hole at one end in one configuration, and on the other configuration there is no hole. I'm allowed to give these the same part number/name/properties, and in terms of stock we would want to keep them as the same part, however if you place both in an assembly the BOM table will list them as 1x each part rather than counting them.
Is this possible?
TIA
  • cameliacummingcameliacumming Member, Channel partner Posts: 2 ✭✭
    Unfortunately no.
    But, In other software we had the ability to set the ENTIRE BOM to read all configurations as the same part, or read each as a unique part.
    but that ends up being useless as well. Because in cases like yours, we would only want this behavior on specific parts.
    a more common example where I work: a bunch of the same air cylinders with different configurations of stroke scattered throughout an assembly
    So I hope if Onshape allows configuration grouping they come up with a better solution.
    Might I suggest a checkbox on the part properties (just like exclude from BOM) that treats all configurations of this part as the same group of instances in BOM?
    that would give us a little more control over when this needs to happen. Not perfect, but maybe it gets people thinking towards a better solution.
    Thanks for your reply - had a feeling this may be the case.
    It would be good to see this in Onshape one day, especially being able to pick and choose which items are counted.
  • John_vd_WerffJohn_vd_Werff Member Posts: 65 PRO
    I ran in to a similar problem where I would like to see configurations of a subassembly to be treated in the BOM as the same item.
    In my case an attached cable is routed differently in each configuration of the subassembly:
  • Jay_DayV_AAgJay_DayV_AAg Member Posts: 5
    +1!
  • S1monS1mon Member Posts: 3,296 PRO
    https://www.onshape.com/en/resource-center/what-is-new/exclude-configurations-selective-restore#:~:text=A%20new%20Configuration%20input%20option,is%20used%20in%20the%20assembly.
  • eric_pestyeric_pesty Member Posts: 2,124 PRO
    Not available for assemblies yet but check out the "exclude from properties" option on parts that enables this.
