Someone modified a document that was not shared with him
Hello!
Today I noticed someone modified my document I am sharing with a colleague. That happened about a month ago but we ignored it because name sounds like a placeholder.
It says: "Modified by Lou Gallo". Who is this? Did some kind of error occur? We have educational license and it bugs us that someone is fiddling with material for our diploma thesis.
Trying to find if anyone asked I stumbled upon someone named "Lou Gallo". Is that the same guy? What are you doing, Lou?
Thank you!
    It may be just wrong displayed name, I was noticing names of different people (presumably from OS) where displayed as document modifiers after update.
  • BogotoboganBogotobogan Member Posts: 5 EDU
    lougallo said:
    @Bogotobogan I do indeed work in the support group here at Onshape.  If you or anyone you have that document shared with was working with our team and shared the document with support could have been opened and modified by us to address a support inquiry.  We do not have access to data by default and do require a share from you to see or access your data.  I believe I am responding to a ticket from you as well on this matter.
    My colleague still claims that she did not ask for support. I personally don't mind you accessing these documents for onshape development purposes. Document is nothing revolutionary or worthy of espionage. We are kind of anxious when it comes to our important documents.
    Anyway, I see this a minor inconvenience. I thank you all for answers. Thought this is some kind of error or malfunction.
    Yes I filed a ticket btw.
    Yes this is similar. Although it is not random people, but "Lou Gallo". I would understand if colleague or I contacted support, but that's not the case. So I got worried a little and asked here.
  • Steve_SpanjersSteve_Spanjers Member Posts: 9 PRO
    Lou Gallo is one of the Onshape support people.  I assume you have the document set to be shared with support?  Did you perhaps ask a question to the support/help staff?
  • mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
    @lougallo so nefarious  :D
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    No. We did not contact support.
